Low pass filter with formula node
Hello, I have 2D array it is have picture I need to apply lowpass filter. I created a formula node . I said, if (x<y) x=0;  and if (x=>y) x=1; y is cutoff frequecy i connected that to a control. But it doesnt work can someone help me out with this. I am not using IMAQ . labview 2009
(4,286 Views)
Did you try using a case structure with 2 formula nodes?
See the attached VI.
Hope this help
J.D.
French Labview beginner
N'oubliez pas de complimenter les bonnes réponses - Don't forget Kudos for good answers
(4,269 Views)
I could not apply that with arrays 😕 comparison becomes borken arrow.
(4,253 Views)
Hi goker,
general hint for posting in this forum:
When you have problems with your VI you should post the VI (or atleast a picture of the block diagram, snippets preferred).
"I could not apply that with arrays 😕 comparison becomes borken arrow."
Comparison functions except arrays too. Please post your VI.
18167i973AFAED90C01574
(4,237 Views)
