Low frequency measurement from Parallel Port
Hi there...
I need to calculate the "on" and "off" time and duty cycle in pulse form from a parallel port. By making the circuit in 5 or 0 V, I just simply put it in my parallel port. The problem comes when I need to measure a very very low frequency. In this case, I want to measure the duty cycle from my operated refrigerator. I need to know when the thermostat goes "on" and when it comes to "off". In my experience, the thermostat will be "on" in about 5-10 minutes and "off" in about 20-30 minutes. So, the pulse might be take for a long periode each.
I've tried with Timing and Transition Measurement wizard or even by using Pulse Measurement.vi which is included in Waveform Measurement category. It only works for 2 Hz and . If I try to set it with 1 Hz or below, it comes the message :
"Error -20308 occurred at Timing and Transition Measurements -> Untitled 1
:4"  (waveform index 0 of 1)
Possible reason(s):
Analysis:  The waveform did not cross the mid reference level enough times to perform this measurement. Check the signal length, reference levels, and ref level units."
Could someone help me please ?
Ricki
(3,018 Views)
How about polling the port every 100ms and do the calculation based on the PC clock?
You didn't mention your spec, however .2s error sound acceptable in this case.
Greetings from Germany
Henrik
LV since v3.1
(3,002 Views)
Dear Mr. Henki,
I've tried to make a 100ms polling, but it doesn't work. Then I saw Pulse and Transition Measurement.vi from the examples directory. I put the same value for the frequency and it also comes the same error message.
Or maybe you have your own program to measure a low frequency ? It doesn't have to be from parallel port. I assume it will be fit to any kind of measurement method. I still need your help, please ?
Ricki
(2,987 Views)
here is a quick shot to give you an idea
Henrik
LV since v3.1
(2,978 Views)
