Low Frequency Measurement using DI-310 Digital Input
Hello
I'm trying to measure the the frequency of a limit switch pulse that's input to the Digital Input of the DI-310 Fieldpoint module.
The pulse is a typical square wave consisting of a 1 Followed by a 0 (A typical Press on the switch)  ,the frequency of the wave ranges between 0-4 Hz ,and due to the low frequency range ,the indication in my case is Pulses Per Minute which can range in this case from 0 to 300 pulse per minute for example.
I tried to do this using a complex way by using a shift register to compare the previous pulse to the current pulse and then increment a counter and then use the rate of change of this counter as an indication for me :s.
What I think will be more accurate is if I can measure the time between each two successive switch presses (0-1-0 followed by another 0-1-0) and then find the frequency by 1/t .but I don't know how to do this.
Please Help !!
(2,579 Views)
Hello shadymohamed,
can you tell me what LV version you are using.
Thank you.
Tobi
(2,540 Views)
just looking for the falling slope and no debouncing ...
Greetings from Germany
Henrik
LV since v3.1
(2,533 Views)
