Loss of signal between SCXI mainframe and vi
I am using a triaxial load cell with the SCXI-1000 mainframe and a SCXI-1321 4-channel module.
I have been utilizing this sytem succesfully for several weeks now. However, as of yesterday the signal seemed to disappear from being passed from the mainframe to the vi. I have done a circuit check and can "see" the signal on the terminals within the SCXI-1321. DAQmx sees the board and mainframe, etc, but no signal is passed thru to the vi.
I stepped away from the laod cell vi I was using and set up a very simple vi with LabVIEW Express. Basically it is the DAQ Assistant and a graph. I set up the channels, etc, very carefully. Still, no signal.
Would any of you chaps have any advice for this conundrum?
Thanks!
(2,603 Views)
I'd like to help, could you post a little more information?
1) SCXI Module are you using? The SCXI-1321 is a terminal block, but what module is it connected to?
2) What DAQ Device are you cabling the SCXI-1000 chassis to?
3) What VI were you using? Was it a shipping example?
4) Are you able to set up a DAQmx Global Channel in MAX and test it there?
5) What version of NI-DAQ do you have?
6) LabVIEW 7.0, right?
-Alan A.
(2,594 Views)
I think I found the problem...the fuse was blown!!
I replaced it and everything is working properly.
Thanks very much!
(2,587 Views)
Great! Best of luck with your project.
-Alan A.
(2,573 Views)
