Lookup table using PXI2535
I have 100 readings I need to do using a PXI4065 connected to a PXI2535.  The relay connections ..to me..don't really have a pattern when calling them to close for measurement.  Some are 4 wire some are 2 wire measurements.  For example Pin 1 is connected to R0C0= DMM+ and Pin 1 is also connected to R3C1= DMM+ sense.  Pin 2 is connected to R0C2=Dmm+ and Pin 2 is also connected to R0C3=DMM+ sense.  Any suggestions on cycling thru the 100's of reading I have to take closing relays that are needed w/o entering them in individually??
thxs
Message 1 of 1
(2,127 Views)
