Looking in wrong directories
I replaced a new sub VI with the original and now I get a strange search pattern going on for which I do not see a solution in the archives. Here's the scenario.
I have a sub vi named myVi.vi located in
c:\1\2\3\4
I rename myVI.vi to newMyVi.vi
I now bring in from CD the original version with the name myVI.vi. The CD version directory is
 d:2\3\4
Now labView is searching for dependencies in
c:\1\1\2\3\4 etc.
These aren't the real file names but I think it makes the explanation easier to follow.
I quit the load and opened the vi to see the error list and it is quite long. Do I need to fix each instance by hand? I have c:\1\2 in the vi search path.
thanks,
jvh
(3,733 Views)
Addendum:
I put the search path at the top of the list but it still wants to check the NI directories first.
jh
(3,730 Views)
Correction: The original post states it is searching in the wrong directory, actually the loading line incorrectly states it is loading the file
c:\1\1\2\3\4\myVI.vi.
It is actually in
c:\1\2\3\4
c:\1\2\3\4
 d:2\3\4
c:\1\1\2\3\4 etc.
thanks,
jvh
(3,724 Views)
I'm confused as to what you actually did. You said you "brought in from CD the original version" which was on the CD at D:\2\3\4. Do you mean you opened it from the CD, or did you copy the VI from the CD to the C:\1\2\3\4 directory? Locations of subVIs are stored within the caller VI as relative paths. Thus, if you had path changes there would be a searching issue.
I don't quite understand what you were saying about having set the search path. What does your viSearchPath key look like in your LabVIEW.ini file?
(3,707 Views)
Yes, that was poorly worded. I copied it from the CD to the C:\1\2\3\4 directory.
 The search path I set from vi front panel Tools > Options > Paths > VI search path
LabVIEW.ini:
viSearchPath="C:\1\2;<topvi>:\*;<foundvi>:\;<vilib>:\*;<userlib>:\*;<instrlib>:\*;C:\Program Files\National Instruments\LabVIEW 2009\resource"
(3,698 Views)
Accepted by topic author jvh75021
jvh75021 wrote:
LabVIEW.ini:
In order for LabVIEW to dig down beyond c:\1\2 you need to add \* to that first path so it searches subdirectories.
(3,678 Views)
