Looking for Terminal Emulator Software
Can anyone recommend a 3rd party terminal emulator for VT100? In my application I also need to send and receive files(xmodem, zmodem). I am currently using an old version of PDQcomm, but would like an current version that supports ActiveX and new technologies like .NET .
(3,568 Views)
What I've used is HyperAccess. It has an ActiveX interface. I never had much luck starting it from LabVIEW but since I needed it to work with TestStand and got that to work, I didn't really spend much time on the LabVIEW side.
(3,546 Views)
I have used telix for windows it has a scripting language that i use to send files via zmodem.  you can write a script to do the file transfer and then close itself and return control back to labview.  you can use the trial version but it has a popup that you have to click before the program will close and return back to labview.   The scripting language is easy to use
- James
Using LV 2012 on Windows 7 64 bit
(3,525 Views)
You can also try using PowerTCP Emulation for .NET. I have not used it personally, but it seems to match your requriements.
http://www.dart.com/dotnet/emulation.asp
Kalin T
Kalin T.
(3,514 Views)
