Looking for HP E1725C driver for Labview 6.1?
want to communicate with HP E1725C by PC over GPIB port"
(2,705 Views)
Hello-
Unfortunately I was unable to find a driver for this instrument either at http://ni.com/idnet. This leaves you with one of a couple options. It may be possible to modify an existing driver to work with this instrument. Otherwise, http://www.ni.com/devzone/idnet/other.htm states a few options to obtaining a driver. Drivers are developed based on demand and popularity so the more requests, the greater the possibility that one will be developed. It would also be beneficial to notify the instrument manufacturer, they often have drivers for multiple programming languages.
(2,704 Views)
I haven't been able to find a driver for this instrument anywhere. You may want to contact HP and see if they have one, though it does not look like they do. You will probably need to access it directly through GPIB calls. Use the GPIB VIs to send strings which the instrument accepts. It should have come with a manual or something which supplies the valid strings. Just use those along with the GPIB VIs (actually, I would suggest using VISA) to build your application.
J.R. Allen
(2,704 Views)
