Looking for Drivers for InstruTech IGM_402 Vacuum Gauge
Does anybody know where I might find some driver VIs already developed for InstruTech Vacuum Gauges?  Specifically, the IGM-402.
Message 1 of 8
(4,014 Views)
Hi Roese,
My name is Ben, i am an Applications Engineer at National Instuments.
Having had a look online at your device i have searched our third party instruments driver page, which can be found at ni.com/downloads/idnet. Your particular device isnt listed however this page has useful links on how to create your own drivers using NI-VISA. What bus does your instrument use?
Kind Regards,
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
Message 2 of 8
(4,000 Views)
RS-485 & communication is in Modbus format.
Message 3 of 8
(3,986 Views)
Hi Roese,
Are you connecting your instrument directly to a computer, either by RS-485 or RS-485 to USB? I have found some information on using Modbus with LabVIEW, including a tutorial , and a Modbus Library for use with LabVIEW. These modbus library functions integrate directly with NI-VISA.
Hope this is provides you with some helpful information.
Ben B.
Message 4 of 8
(3,981 Views)
Sorry to be six years late in responding, but the students and professors in our lab at Cal State Fullerton, using the InstruTech manual to get the communications commands, just posted this set of example VI programs. Perhaps you or others still have a use for these.
http://forums.ni.com/t5/Example-Program-Drafts/InstruTech-Hornet-402-Vacuum-Gauge-Control-VI/ta-p/36...
Josh
Message 5 of 8
(3,768 Views)
Thanks for the link, but it takes me to a "Document not Found" page
Message 6 of 8
(3,760 Views)
I'm sorry, after uploading that as an example program draft it seemed to take a longer than expected amount of time before the link worked for anyone but me. Now it seems to be up. Does it work for you?
https://forums.ni.com/t5/Example-Program-Drafts/InstruTech-Hornet-402-Vacuum-Gauge-Control-VI/ta-p/3...
Message 7 of 8
(3,707 Views)
Did you use RS485 2-wire or RS485 4-wire for this?  Also, were 120 ohm termination resistors needed?
Message 8 of 8
(2,392 Views)
