Look up string from numbered array element.
I will work up that idea.  Thank you very much I think I can make it work.
Greg
Greg
Message 11 of 12
(623 Views)
The attached zip file shows screenshots of the sub VI's I created to do what you suggested.  I created a master ID text file that is read into a master string array.  Each string ID's row location corresponds to the component's column location in the test data.  An intermediate array of failed column elements is indexed out by a loop and used to insert the string ID from the master array into a failed component string array to display on the front panel.  It is saved to the desktop too.
Greg
Message 12 of 12
(599 Views)
