Logo on Application
Hello to all.
First of all thanks a lot for reading this post and being able to help.
I would like to do an application which simply has to recognize Logos.
So the structure is the next:
1-User has to take a template (which Labview has to compare if the Logo is like the template).
-If the next image is not like the template, then red light.
-If the next image is like the template, then green light.
I think that the best way is to use a comparision between image and a template. but I don't know if there is a better way. Is there?
Thanks a lot.
Message 1 of 11
(5,594 Views)
Accepted by GerdW
If you have Vision Module, check Pattern Matching examples.
-Does the logo contain characters only or some extra graphic or image?
-Can you provide samples?
uday
Message 2 of 11
(5,528 Views)
Hello, thanks a lot for replying:
I answer your questions:
1- Logo can contain characters and extra graphic or image.
This application is for detect any logo that user wants.
Some of those logos can be the next:
Resultado de imagen de logosResultado de imagen de logosResultado de imagen de logos
For examples...
Message 3 of 11
(5,492 Views)
Hi A.,
Write an interface VI to upload your "logo images" to Google's image search engine: https://www.google.com/imghp
Then check the search results… 😄
Message 4 of 11
(5,487 Views)
Thanks for replaying.
I do not understand your answer.
Thanks.
Message 5 of 11
(5,484 Views)
Hi A.,
from your task description you need to analyze ANY KIND OF image. This might be problematic as the target of "pattern recognition" usually is to compare an image with a previously known set of patterns!
On the other hand Google already can "recognize" ANY KIND OF image, so all you need to create is an interface to their website/image search engine… 😄
Message 6 of 11
(5,482 Views)
I think I didn't explain really good.
First user create a template of the logo and then the pattern matching compare with that template.
That I meant is that logo can be anyone of them but user has to create a template.
Do I explain well?
thanks a lot.
Message 7 of 11
(5,480 Views)
Hi A.,
now you explained your task a little better.
See message #2 and use IMAQ PatternMatching functions…
Message 8 of 11
(5,476 Views)
Thanks! PatternMathing works for this!
Message 9 of 11
(5,445 Views)
Hi A.,
you surely wanted to mark udka's message as solution, not my comment on it.
I did this for you… 😄
Message 10 of 11
(5,437 Views)
