Login tab (LabVIEW NXG)
Hi guys,
I tried to make a login tab in my VI, but it doesn't seem to work quite as I expected. What I tried to do is to make a tab control with the first tab being login-window. When the user writes in a username and password that matches the one from the text file, the user unblocks the next tabs. The problem I experience is that the username and password I write in the strings are not read and the returned string is empty. Also, I can't figure out how to make the other tabs "blocked" for access during the login session... Any ideas? login diagram.PNGlogin window.PNG
(2,770 Views)
I'm you need to play with property node a little bit for that, since you need to edit the property of an object (tab) in run time.
Please refer to:
Property Nodes with LabVIEW NXG
I can't really help much, since I don't have NXG. But it should looks more or less like this:Page Disabled.pngimage.png
Set the first page (Login) to Enabled, and the rest as Disabled. After a successful login, set all the property to Enabled.
(2,706 Views)
