Logical AND, Logical Shift
hello,
can someone explain this?
(3,520 Views)
Hi W3SK,
it's because you use "logical shift" and not "rotate".
Mike
(3,513 Views)
Read the context help for the Logical Shift function.
"y can be any numeric representation. If y is greater than 0, the function shifts x left y bits (from least significant to most significant bit) and inserts zeros in the low-order bits. If y is less than 0, the function shifts x right y bits in the positive direction (from most significant to least significant bit) and inserts zeros in the high-order bits."
Put in -4 to rotate 4 bits to the right.
(3,509 Views)
thanks, Mike Smiley Wink
(3,501 Views)
