Logging Mixed signals to TDMS
Maybe not the best way to do this but I currently have the following setup to plot 8 digial signals and 8 Analog signals to a mixed signal graph:
I now would like to save those signals to the a TDMS file
From examples I've looked at, it I seems that I could use the 'configure logging.vi' block
Can I use this block in the same way with my setup?
Where I am unclear is, if yes, how to wire these blocks so that the digital and analog signals are written to the same TDMS file correctly.
Alternatively I could always export the plot to excel but I feel that its not the best way to store the data....
any advice on improving my current setup is also welcomed! 😉
(3,510 Views)
(3,424 Views)
@sherzaad wrote:
found my solution here! 🙂
TDMS Data Logging From Multiple DAQmx Tasks in LabVIEW
I till have a problem.... 😒
the TDMS write Function block is not accepting the digital waveform input!
from the help for that block its seem that:
"If the data input contains  compressed digital data, you must enter the name of the compression channel as the first entry in the channel name(s) in array."
"channel name(s) in" accepts a string but what should I write in it is not clear to me! 😞
How to setup the block to accept digital waveform input?
Any help would be much appreciated...
(3,406 Views)
the TDMS write Function block is not accepting the digital waveform input! ....
Ok.... from what I have been able to understand is that this block does not accept a 1D digital array waveform.
So... the next question is:
How to save the digital waveforms to TDMS?
Anyone any ideas????
Really need a solution to this problem....
(3,388 Views)
TDMS is a very flexible way for storing data.Some ideas:
1) Convert each digital channel to an analog waveform, make an array and save it to  TDMS (this creates a very redundant data file, a good and fast approach only if your sampling rate is low and your recording time is not too high);
2) Save your binary port data as U8/U16 and store only port status variations with relative event timestamps (like xy couples, where X is timestamp, Y is port status). This is a more compact way to store, but not as a waveform data type.
(3,362 Views)
