In a LabVIEW PDA application, I need to use a 'Slider' control with a logarithmic scale. For this, the scale has to be made logarithmic using the slide control's properties & check the 'Logarithmic' option under 'Scale' tab. I observe that the scale becomes a logarithmic one on desktop but on PDA, the scale does not become logarithmic i.e. it is still the default scale. I have attached a sample VI which shows this problem on PDA. Has anyone faced this problem before? Is there a solution or a workaround for this?
Thanks & Regards,
Subhashini
