Logarithmic graph
Hi all.
I want to generate this type of signal but i don't have any idea how to do this. Can you help me, please?
Thanks !
(5,089 Views)
Do have a problem with programming or with the math to generate the data?
(5,057 Views)
i have a problem with both.
(5,052 Views)
What have you tried so far?
(5,049 Views)
Hi Claudinho,
Then maybe you should start with learning the math first?
Are you looking for something like this?
(5,044 Views)
You also have a third problem: asking questions. 😄 Is this for continuous generation or a single-shot? What's the purpose? What's the desired datatype? Is this going to an analog output? What is the amplitude, frequency, sampling rate, and time constant?
A simple square wave with an exponential filter would probably do the trick. Here's a very simple example to get you started. (Probably needs a few tweaks for initial values, offset, amplitude, a, etc.))
(5,033 Views)
