Lock front panel in an event structure
@Ravi Beniwal wrote:
 But it makes all the difference if you have more than one event structures in the VI.
Your problem is not the front panel locking, but the misguided coding that places slow code inside event structures. Such code should execute in parallel (e.g. using a queues) to make sure the event structure is ready as quickly as possible.
Events should not contain slow or interactive code.
Message 11 of 13
(915 Views)
Hi altenbach, this was not really my problem. I was merely giving a scenario to clarify the difference between using front panel locking or not, to conclude this thread. This was, by no means, recommendation on putting slower code in event structures.
Message 12 of 13
(908 Views)
Hi All,
Must admit that as i normally use a producer/consumer loop in situations like this i have never actually come across this as problem and am surprised at this behaviour. I like others here thought that locking the front panel stopped pressed events from also queuing. I played around with the given example and found that even if you 'disable' button 2, whilst button 1 event is occurring, and 're-enable' when exiting if you have the 'lock front panel' checked it will still fire button 2 event (if clicked), if you do not have it checked then it will not. It seems that all locking the front panel does is queue the fact a click has taken place but deal with this click after button 1 event, whereas if it is not checked it deals with the click straight away. If you have the fp locked then if you click on the disabled button whilst button 1 event is taking place then its event will still be triggered as the click is handled after this event and the button has been re-enabled. If you do not have the fp locked and you click whilst event 1 is happening the button 2 event does not happen as the click is dealt with straight away and in this case the button is disabled so nothing happens.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 13 of 13
(898 Views)
