Lock To Plot-Problem
I want to set the cursor to the maximum value in a X-Y-Graph. This doesn't work
when the cursor is locked to the plot. So before I set the cursor to t
position I unlock it. After setting the position I lock it again and *surprise*
it jumps to another position, which is not the one I set. This isn't happening
when I do the unlock/lock manually. I can't see a difference between the two
things. Any ideas?
Nico
Nico Schmidt IPK/IWF eMail : nico.schmidt@ipk.fhg.de
Sekr. PTZ 4, Pascalstr. 8-9 Phone : +49-30-39006342
D-10587 Berlin
(3,295 Views)
You need to use the plot and index attributes on locked plots, not the X
and Y
values.
Greg McKaskle
> things. Any ideas?
> Regards,
> Nico
> D-10587 Berlin
(3,295 Views)
