Localization
Does anyone have a tool to translate the string file generated by the
Export Strings function in LabVIEW into a target language?
OR
What is the best way to translate this file so it can be imported back
into LabVIEW?
(3,883 Views)
There is currently no parser or translating utility for the exported string files that I am aware of. There is however a Dev Zone Tutorial that might help explain the process.
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/6d94f90fc9b93aad862568a7007cd4c0?OpenDocument
There is also some more info about it in the G-Reference Manual. The most important things to remember are not to alter the tags and not to change the control labels. Otherwise, LabVIEW will give you an error when you try to import the file back.
(3,883 Views)
Yes.  I provide some free tools for translating the string files exported by LabVIEW.  Go to www.jpotech.com and click on downloads.
http://www.medicollector.com
(3,382 Views)
