Local Security Authority LabView 2024 Q3
Yes, that's also correct. The Sys Config installer installs those (previously) problematic DLLs. So any machine that runs your LabVIEW EXEs will need Sys Config 2025 Q2, installed either manually, or as part of your LabVIEW-built installer.
Message 61 of 85
(5,268 Views)
@GabeJ replied "Correct" to this
@Mads wrote:
I assume this (the System Configuration 2025 Q2 update) will fix the mDNS issue regardless of whether the installers you make afterwards actually include the System Configuration component...correct?
So, when you @Darren say that any machine running your LabVIEW exes will need Sys Config 2025 Q2 there seems to be a contradiction:
Is it sufficient that the installer of the exe was made one a machine that had Sys Config 2025 Q2 installed, or do we actually have to include Sys Config 2025 Q2 as a component in all installation sets that risk including mDNS (i.e. an exe that requires VISA e.g and so gets mDNS included, but not Sys Config itself)?
Message 62 of 85
(5,208 Views)
You may have to to make sure to specifically select the NI System Configuration 2025Q2 installer in the Installer Build Specification. That Build setting often lets you select different versions of packages if they were ever installed on your computer, since they reference the installers themselves that are cached, not the installed files on your system (of which you can only have one version installed when it is about drivers like System Configuration).
Rolf Kalbermatter  My Blog
Message 63 of 85
(5,203 Views)
Just did a quick test now using a clean virtual Win 11 machine comparing an installer made with LabVIEW 2025 Q1 with System Config 2025 Q2 installed: First with an installer without that component included and then with (well, I chose to include the component: System Config 2025 Q2 RunTime only, which added 140 MB to the installer size)...
Both installers install what seems to be the exact same mDNS dll; Dated 11 Feb 2025 and signed with a ceritificate dated 23. June 2024...
I then used an old installer created prior to the SysConfig 2025Q2 install on the development machine (still LabVIEW 2025 Q1 though) and it installed an mDNS dll from 2023. So things did change, and including the System Config 2025 component does not seem required for that change...
(My test machine in this case did not complain either way though, so whether the new DLL / certificate is OK was not clarified. I'll need a different test machine setup that recreates the original issue for that...).
Message 64 of 85
(5,186 Views)
11 Feb 2025 is the correct date for that DLL.  Look more closely at the signatures, though.  There is an NI signature on there that was applied on June 23, 2023.  The important thing, though, is the second signature, from Microsoft, that was applied on December 16, 2024.  That certificate has the Windows Software Extension Verification EKU, which is what should allow this DLL to load in a secure LSA context.
Message 65 of 85
(5,160 Views)
Can you tell me where the file is stored so I could rename it?
I'm having the same issue.
Windows 11. LabView 2025 Q1 Community (installed all the packages).
Message 66 of 85
(4,020 Views)
Has this been resolved by some Windows update or something? I just realized I haven't seen this pop up all week. I restart my work PC every morning, and the box has always popped up. I am pretty sure I was still seeing it last week, but maybe it has been longer.
Message 67 of 85
(3,981 Views)
I'm not aware of any, but that doesn't mean it didn't happen.  Do you have the latest version of the nimdnsnsp.dll?
Message 68 of 85
(3,972 Views)
64-bit: C:\Program Files\National Instruments\Shared\mDNS Responder\nimdnsNSP.dll
32-bit: C:\Program Files (x86)\National Instruments\Shared\mDNS Responder\nimdnsNSP.dll
Message 69 of 85
(3,971 Views)
The simplest way to install the latest versions of nimdnsNSP.dll is to update System Configuration. Open NI Package Manager, Browse Products, in search products box type System Configuration, select System Configuration, Select Latest Version (currently 2025 Q2), Install. When install has finished, restart machine. This is the solution that was passed to me via NI Support.
Message 70 of 85
(3,488 Views)
