Loading a different RT Menu using VI server
        Using LV 7.1 can I select what Run-Time menu I would like to run a VI with. For example I would like to have two RTM files. Depending on the situation I would like to lauch the VI with either one or the other Menu. If this is not directly possible before running the VI, is it perhaps possible to send a flag and then do once the VI is running.
        I
(2,903 Views)
Here's an example how to do it. But, when i was testing it, i did not get the expected result. Look at it, tell me if it works for you. All the files are included in the attached zip file.
Goodluck,
Ananda
(2,886 Views)
Thank you, but I been able to accompish what I needed to do by setting the Menu path property. I wasn't aware that this property existed. Now I know and problem solved!
(2,874 Views)
