Loading .NET 4.0 assembly
Yes I did restart LV.
I copied your config txt and it works now!
I still don't the difference with mine.. maybe typo??
Thanks very much for your fast help!
Message 11 of 16
(2,455 Views)
Well, my guess is that you duplicated the tag <configuration>.....
Norbert
Norbert
Expert: Geometry
Message 12 of 16
(2,454 Views)
Hi Norbert,
I have the same problem, i copied your text and saved it as  LabVIEW.exe.config.ini and placed at labview home folder where Labview.exe
I am using LV2010sp1,win7 64bit.
i attached .dll file.
 please provide solution.
Hari
Message 13 of 16
(2,334 Views)
Hari,
is the file "LabVIEW.exe.config" or "LabVIEW.exe.config.ini"?
It must be the first one....
Norbert
Norbert
Expert: Geometry
Message 14 of 16
(2,315 Views)
hello
sorry about putting old topics up, but I have the same problem.
Using labview 2015, I can't find the file "labview.exe.config"
has it been replaced by something else towards versions?
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
Message 15 of 16
(2,080 Views)
You need make the config file using notepad and save it as LabVIEW.exe.config
Message 16 of 16
(1,695 Views)
