Loading Hex Files with multiple records with each line starting with : record marker, how do I load this hex file into a front panel table ? thanks in advance, Jeff.
I have written a routine that loads a Hex file, checks for record marker,length,address etc then loads the data into a table on front panel. However, my routine only loads single record hex files. I need to be able to load multiple record files, I need to identify the ':' colon record marker start for each record in the hex file, I just can't see how to loop my routine so that all records with ':' prefix marker are loaded.
(2,505 Views)
Jeff,
I'm not exactly sure of what you are trying to do. Is it possible you could post your code, or a screen shot of the diagram in question, so that I can get a better understanding, and possibly offer some assistance?
I am familiar with hex files, but not with the : marker separating records. This may be able to be solved with simple text parsing, and as I am not familiar with how you are retrieving and/or displaying the files, I require more information.
(2,505 Views)
