11-25-2008 12:51 PM
I have a problem when I load up my built application and I can't figure out what's going on. Here is a portion of the summary, which seems to say that certain paths were expected. How can I configure my build to know what path to look for without throwing out this warning?
11-25-2008 01:09 PM
11-26-2008 03:32 PM
Hi Orion,
I would need some questions answered first prior to giving any suggestions:
1. Are you building an installer or an executable?
2. How many VIs do you have in your project?
3. What additional installers are you using in your project besides the LabVIEW Run-Time Engine?
Ipshita C.
11-26-2008 03:43 PM
I am building an application without an installer.
The above picture shows pretty much all of the VIs in my project. 15 or so.
I already have the DSC run-time and the Labview Run time so I didn't think I needed anything else.
12-01-2008 02:43 PM
H Orion HE,
What version of LabVIEW are you using (and therefore version of the Application Builder and DSC)?
What is your operatng system?
Is "Application.exe" the name of your executable (Target filename) and/or the name of a directory (Destination directory) you saved your executable to?
Are all of the VIs in question subVIs, or are they being programmatically called from your main VI using VI server?
When you run the executable on the development computer, are the same warnings given?
Did you hardcode any VI path names? (If you put the executable in the same location on your second computer as the first, do the warnings appear?)
Kevin S.
12-01-2008 02:47 PM
