Load-pull Power contours
I was trying to implement a code to plot the Load-pull power contours which can show me the maximum output power and the other 3dB power contours but it seems I gave up.
Is there any of you could help me please with this problem. I wish if there is a ready code for that. the one which is already in the Labview is very slow and doesn't shows me the contours that I want.
Thank you in advance for your attension
(2,965 Views)
The Max height is a point take 0.5 off the Max
"Should be" isn't "Is" -Jay
(2,906 Views)
sorry, what do you mean exactly, I did not get you exactly
(2,903 Views)
I saw your block diagram note.  Not that you saved any data in the controls as default values but, If the max value is a single point and you want a contour line .... Well, a line segment just can't be drawn with only 1 point can it?
(2,900 Views)
