Load bluehill 3 API into LabVIEW
Ok, I have worked with the Null key and have gotten it so that the key is no longer null from the APIObject, which I changed to a control. I added a second node that I can hover over and see that it does have a key. However, the SetAPIReference still throws a null reference error. At this point, I am pursuing a different method of solving the problem, since all I need the API to do it send a TestStart event. I believe I can make a transducer that will read an LED of the Instron's control panel and just use that to trigger. I am still open to suggestions to get this to work via .NET.
Thanks for the help though.
Luke J
Message 11 of 19
(2,908 Views)
Give us new screenshot?
George Zou
Message 12 of 19
(2,900 Views)
Capture2.PNGHere you go. As far as I can tell, both have the same key, which I am not sure matters. Anyways, when I run it, it still throws the "Key cannot be null" error.
Luke J
Message 13 of 19
(2,883 Views)
You might have to use a constructor.
George Zou
Message 14 of 19
(2,878 Views)
Ok, I added the constructor for BluehillAPI, which needs a System.Object Argument, so, I constructed that too. It still throws an error, but I haven't seen this one before, which is exciting.Capture3.PNGCapture3.PNG
Message 15 of 19
(2,868 Views)
I am linking an NI Forum post that discusses this in a bit more detail. Are you encountering this error in development mode or in an executable?
https://forums.ni.com/t5/LabVIEW/NET-Control-Error-1172-Only-in-executable/td-p/2497534
Shezaan Noorani
Message 16 of 19
(2,852 Views)
Is there any other constructor available?
Is there any examples available in other programming language?
George Zou
Message 17 of 19
(2,844 Views)
That is the only constructor available for the BluehillAPI.
There are some examples in C#, which I can open, but I am hesitant to post them online due to this heading:
// Property of Instron Corporation
// Source Code is Confidential
// Copyright (c) Instron Corporation 2010
In theory, I can change the BluehillSkin.dll to be strong named, but I haven't tired it yet.
Luke J
Message 18 of 19
(2,836 Views)
There are many constructors available in the assembly:
George Zou
Message 19 of 19
(2,824 Views)
