Load STL geometry can not load read only file
I am using the Load STL Geometry VI to load a 3D model that I am using in a scene.  A path constant pointing at the file is wired to the Model File input of the VI.  If the file is read only, the VI does not load it, but opens a file dialog box instead.  If the file is not read only, everything seems to work fine.  Is this expected behavior?  I wouldn't think that just loading the file should depend on whether or not it is read only.  Is there a way to use a read only file in this situation?
(2,898 Views)
Accepted by topic author cbfsystems
Hi cbfsystems,
You are correct that this is not the expected behavior of this particular vi.  This is a known issue that our R&D department is aware of.  For your reference, the number associated with this issue is #281409.
We are sorry if this is of any inconvenience to you.
Justin D.
(2,879 Views)
