07-11-2007 09:59 AM
07-11-2007
10:24 AM
- last edited on
10-07-2026
02:57 AM
by
Content Cleaner
LVM has an extensive header system which does not have the same number of columns as the data itself. However, LVM was designed to be easy to parse, so it should be easy to get what you want. If you just want your data, do a search in the file for ***End_of_Header*** and the column headers line will be next. If you want to read the header data, check out the LVM spec.
07-11-2007 10:30 AM
| Channels |
| Samples |
| Date |
| Time |
| X_Dimension |
| X0 |
07-11-2007 12:11 PM
07-11-2007 12:28 PM
05-14-2008 04:57 PM
