ListBox MutiLine
I am using a listbox control in my VI
I am populating it with strings that are created within the VI
My problem is, if the string length is too long I cannot see it in the listbox, it runs out of width.
When I right click on the control I can select multi line input but this only seems to work if I wanted to manually enter.
How I can I make it 'wrap'?
Thank you in advance
Lee
Message 1 of 9
(5,628 Views)
Hi Lee,
it seems quite easy to put some line breaks in the strings:
"1 2" is marked as first line in the listbox…
Message 2 of 9
(5,625 Views)
Good morning, thank you for your quick reply
Yes from your example, very straightforward.
My problem is that the contents of the list box are saved to a file which is then  read back in another VI and decoded and so I didn't want to introduce any further elements into the inputted string
Message 3 of 9
(5,619 Views)
Hi Lee,
You don't need to "introduce further elements", you only need to put some line breaks into long strings to enforce word wrapping…
Message 4 of 9
(5,612 Views)
If I use a line feed constant it gives me the desired look in the list box but as u can see, I also save this to a text file and I would prefer it was all on the one line?
Message 5 of 9
(5,610 Views)
Hi Lee,
you only need to add those line breaks for the Listbox object names.
Nobody said you need to add them to your data written in the file…
(All you need to do is to branch a wire!)
Message 6 of 9
(5,605 Views)
Of course yes, thank you
Can I ask one more question on listboxes. Am I able to add a border to each row so that it shows a clear split between each row. I couldn't see how to do that
Message 7 of 9
(5,602 Views)
Oops found it ... horizontal lines ....
Many thanks for your help
Lee
Message 8 of 9
(5,601 Views)
Please mark the solution and kudoes are a great way to say "Thanks for the help."
aputman
Message 9 of 9
(5,575 Views)
