Linx+Arduino Wrong frequency output of digital square wave generator
Hello
I am going to use linx to program a stepper motor control VI. The stepper motor driver I use is A4988 and TB6600. The stepper's rotating speed depends on the frequency of pulse input to the driver, so I use a digital square wave generator in linx to attain this request.
But now the output frequency 60Hz(which is shown in an oscilloscope) is not identical with the frequency 1Hz I input in my VI. I do not have any idea about this problem.
Appreciate all of you helping me.
(2,544 Views)
Hi Luca,
May i know if the duration(ms) and channel match with your input when you run your Vi?
(2,485 Views)
Thanks for your reply~
As in the picture I put above, the channel is 7 and the duration is 1000ms. I tried to change the channel and frequency, but I cannot get the square as I expect.
(2,468 Views)
Is there are need for you to update the frequency all the time?
Try to only set the frequency one time and see what happens
(2,458 Views)
Thanks, dkfire
   After I delete the while loop, the frequency is still about 60Hz as before. And there is a new problem. The duration I set is 40000ms, which means it might output a 40-second square wave. However, the square wave I get is more than 10 minutes. If the duration set 30000ms, the actual output time is about 1s(I record it by my smartphone's slow motion). The result is pretty inconsistent. I doubt the timer or clock in Arduino or Linx goes wrong. But I do not know how to check that.
Appreciate your help~
(2,454 Views)
Hi Luca,
I helped to ask your question under Linx discussion forum, and I get a reply from a person and I think this might help you. You can go ahead and read through what's in the link
Hope this helps
Fiona, NI
(2,442 Views)
