Linking VI and a Sub VI
Hi everybody,
How can I send data from the VI to the sub VI without a direct link with a think like a property node or some think like this.
Message 1 of 20
(3,564 Views)
Hi Basile21,
you can use queues or notifier. Can you explain what you need? You can also be flexible with using property nodes. Smiley Wink
Mike
Message 2 of 20
(3,561 Views)
Use the Set Control Value method, if you have a VI reference. If you have a
control reference, use the value or value (signalling) property.
It's not very decent programming to do this. It's better to use a buffer
vi/smart global/lv2 style global/action engine.
What are you trying to do?
Wiebe.
Message 3 of 20
(3,553 Views)
Hi Wiebe,
I have a VI in wich I have a Sub VI in wich I have a waveform chart and my purpose is to delete the graph at each run of this VI.
Thanks for your help.
Message 4 of 20
(3,546 Views)
Hi Basile21,
in this case you can simply delete the graph in the subvi. Clear the graph before you do something else.
Mike
Message 5 of 20
(3,518 Views)
Hi Mike,
Thanks, but I want to reset the graph automaticly before each run.Smiley Wink
Message 6 of 20
(3,503 Views)
Hi Basile21,
yes, i understood it. So insert the delete function in your vi, before some other code.
Mike
Message 7 of 20
(3,498 Views)
I don't know if this is your case, but i clear the graphs ant indicators at the end of the vi. So the next time it is called, it is ready.
Message 8 of 20
(3,489 Views)
Hi Pnt,
Yes it's what I want to do, can you tell me how you do it please.
Thanks for your help Smiley Wink
Message 9 of 20
(3,484 Views)
the simple way. Wire an empty array to it.
Message 10 of 20
(3,478 Views)
