Link a message to Boolean state of an LED
I am a new user to LabView and I am preparing an HMI for an electrical power system which contains breakers. I can control breakers in the system with the LabView VI I have made and can toggle their states. The states are reflected with a boolean square LED so the breakers can be ON or OFF! It seems fine now but I would like to do something more complicated. I would like to link a message, like a warning to the OFF state of the LED. So, if a user turns the breaker to OFF, I want a warning to appear with a string which says: "Breaker #.. is open!".
Is this possible to do in LabView. How can I link the LED state to a string? Any help is appreciated. Thanks!
(1,477 Views)
Please take one or more of the free LabVEW programming tutorials and you will find your answer
https://www.ni.com/getting-started/labview-basics/
=== Engineer Ambiguously ===
(1,464 Views)
Hi mehrdad,
@mehrdad6687 wrote:
I am a new user to LabView …
  • Yes, it's possible.
  • Use a case structure (or even better a Select node) to "link" the LED/button/switch to your string indicator…
As a "new user to LabVIEW" you really should take those Training resources as offered at the top of the LabVIEW board!
(1,448 Views)
