Linear ramp voltmeter
Ciao. Come faccio a implementare un voltmetro a rampa lineare a partire da questi due blocchi già elaborati? Dovrei inserire un confronto della rampa con l’istante t* in cui incontra il segnale e con t0 in cui passa per l’asse delle ascisse.
(664 Views)
Hi Gabriel,
@Gabrielectronic8 wrote:
Hi. How can I implement a linear ramp voltmeter starting from these two blocks already elaborated? I should insert a comparison of the ramp with the instant t* in which it meets the signal and with t0 in which it passes through the x-axis.
What exactly are you talking about?
There is no "instant t*" in your image, there is no "x-axis" in the image, there is no t0 in the image…
There are no "voltmeter" functions visible in the image…
What are the sequence frames good for?
(647 Views)
