Linear Regression or Curve Fitting?
I would like to perform linear regression operation over some data that I have collected during test. What is the difference between linear regression and curve fitting? Can I use curve fitting VIs available to perform linear regression? If no, where can I find VIs or information regarding linear regression in the LabVIEW 6i?
Thank you for your help. It will save me many hours of search.
(3,604 Views)
there are some very good examples in the examples directory of LV. C:\Program Files\National Instruments\LabVIEW 6\examples\Analysis\regressn.llb\Regressions Demo for example. You must have a LabVIEW full development system.
Stu
(3,604 Views)
Thanks for your help. It works.
NY
(3,604 Views)
