Linear Fit did not work - LABVIEW 2020
I need to do a simple program to read data from txt file and prompt it on graph with Linear Fit function ( y = ax + b), but in output of this function I don't have any data. On the XY graph there is only measurement points. I don't have any idea now how to deal with it.
(2,849 Views)
As a first step attach your VI and datafile. We cannot debug pictures. What is the error code of "linear fit"?
(2,839 Views)
I attached my files now.
(2,829 Views)
Thanks.
(2,800 Views)
Accepted by topic author lukaszc331
Error was -20002, i.e. the x and y arrays have different size. Try this instead:
(I had to tweak the format to use comma as decimal delimiter)
On a side note, ALWAYS wire an indicator to the error out. Sometimes it wants to tell you something.
(Also, please don't maximize front panel and diagram to the screen. Very annoying!)
(2,797 Views)
Thank you very much 🙂
(2,760 Views)
