Limit Cell String Size
Thank you for the sample. 😄
I created my event structure with 2 events.
First one is my multicolumn listbox with a mouse down event.
Second one is my multicolumn listbox with a value change.
My string length works , but only if i enter the location of my row and column manually.
I can't seem to get the position of the cell with my mouse down event.
The cell position row and column do not update with my mouse down event, always row 0 & column 0.
I used a property node with the element ActiveCell and sent the values to indicators, so I can see my results.
Do you know why the values in my indicators for the active cell are not updating?
Message 11 of 16
(1,926 Views)
You need to use a key down event, not a mouse down because it is possible to tab between cells and never catch a mouse event.
aputman
Message 12 of 16
(1,916 Views)
Switched to a key down event, but the rows and columns are still not updating from the event.
I can grab my row location from the multicolumn listbox property node Value element, but not sure if there is another good way of getting the column position.
Message 13 of 16
(1,894 Views)
I'm not sure what you have tried since you aren't sharing any code.  What did you put in the key down event?  Is the above picture what is in the key down?  If so, that's your problem.
As an aside, the picture i posted a few posts back is a snippet.  Drag it to your desktop and then into a block diagram and it will pop down the code embedded in it.  Do that and make sure you have the correct property node in the key down event.  I'm using the Edit Position property which returns the row and column where the text edit is happening.
aputman
Message 14 of 16
(1,881 Views)
My issue is that I was using a multicolumn listbox and not a table.
They don't share similar properties and was limiting me from getting the cell row and column the same way.
In order to get it to work the way I wanted with a multicolumn lisbox, I was able to use one event.
The event i used was Edit Cell and it gave me access to the row and column of the cell being edited in the Event Data Node.
Thank you for your time and help
Message 15 of 16
(1,862 Views)
That changes everything then.  Your first post said "table".  Be specific because these are not the same.
Use the Edit Cell (?) filter event and you can change the data on the fly before the control is actually updated.  Or you can check Discard and it will ignore the user input altogether.
aputman
Message 16 of 16
(1,851 Views)
