Light multiple leds
I am trying to write a VI where a dial controls how many leds are lit up at a time. For example if dial is set to 2 then 2 leds are lit up. I have attached my VI as it sits now. I am unsure how to go about this anymore since i couldnt get the case structure to work, unless i just don't know what I'm missing or need.
Thanks!
(3,734 Views)
Nevermind figured it out. Smiley Tongue
(3,722 Views)
No, you only attached a picture. Please attach the actual VI.
Since you cannot light a fractional number of LEDs, the control should probably be an interger. I would also use an array of LEDs, much simpler! You also need to slow down your loop. Currently it spins millions of times per second. You also don't need a case structure.
Try it!
(3,715 Views)
Don't know how to use arrays otherwise I would!
(3,708 Views)
Do you want to learn how to use arrays?  Try them, you'll like them. 🙂
Jim
(3,657 Views)
Or convert the numeric control value directly to an array indicator:
(3,640 Views)
