License error
I am installing LV PDS 8.0 version and after the complete installation an error message is coming saying Error2 labview activation faliled.And when i reboot my system and try to open the LV it says an LV licensing error has been occured and the LV is not opening can any one help me out?
Regards
Aks
(Appreciate answers by giving KUDOS)
Hit the stars.............. sky is not the limit.
(3,424 Views)
It looks like there was a problem with your activation.
I would go into NI License Manager (Start->programs->National Instruments->NI License Manager) and expand LabVIEW 8.0 Development System and look for PDS.  You should see a green square if the product is activated.  If not, right click on the square and select "activate" to go through the procedure.
This is about as far as we can take it over the message boards.  If the steps above do not help you fix the issue, I would suggest calling in to customer service.
Let me know if you have any more questions!
Craig D
Message Edited by Craig D on 07-17-2007 08:14 AM
(3,385 Views)
Thanx for the reply ,i checked the procedure before itself only but there was no license manager detecting in the system so i called up the NI Support and they asked me to format the OS and one thing i told them the Error it was Error Code 2.
Regards
Akshath.HK
Associate Engineer
AutoTec Systems
Regards
Aks
(3,362 Views)
