Library Deployement Error in DSC
Hi all,
I was trying to bind two shared variables programatically and deploy the library after the same. I am having a Library 1 with a Variable 1and Library 2 with Variable 2. I made a progarm to bind the Variable 2 with Variable 1. Eventhough i am able to bind successfully, the library Deployement is giving an Error 1.
I dont know is it a bug with DSC 8.2 or there are other methods for binding the shared variables programmatically.
I am attaching the code with this post.
Kindly help me to overcome this issue.
Thanks and Regards.
Mir
Coding is a combination of intelligent and creative work - someone
(3,332 Views)
Hi Mir,
May I ask what your application is?  Why do you need two separate libraries?  See the following: http://digital.ni.com/public.nsf/allkb/8EF71E1DDDC36C908625716900594B50?OpenDocument
Jeremy_B
(3,301 Views)
Hi Jeremy_B,
Thanks for your support.
My application is related to Fielpoint.
I have two identical Fieldpoint Controllers both acquiring data from its module and updating its local libraries. At a time any one of these cFP will be active. I have another GUI running in a local PC which is displaying the the Fieldpoint Channel Details and having a shared variable library locally. I have one VI to detect which cFP is Active and if cFP 1 is Active, i need to bind the local shared variables to cFP 1 variable. If cFP 2 is Active i need to bind the local variable to cFP 2 variables..
i hope you are clear with the scenario.
Waiting for your reply.
Mir
(3,299 Views)
Hi Mir,
Try deploying both libraries before you bind the variables.  That seemed to work for me on my machine.
Jeremy_B
(3,282 Views)
Hi Jeremy,
i tried your method also. Before binding i deployed both the Libraries. Can you attach the trial code which you tried in your PC  so that i can try the same in my PC also.But result is same. Error 1 . But when i  am using Project Explorer it is deploying successfully. i am really worried about this behavior. Is there any other way to bind programatically.
Any suggestion will be appreciated.
Mir
(3,270 Views)
