Learning to use two DAQ devices at same time; Please comment.
My reason for playing around with two DAQ's at one time is that I have an application that will require more than one daq. Because many I/O. So I just wanted to see if I could get two working. Please see my attached VI, and comment on it please. Is there a better way? have I used the right approach?
I'm using measurement computing's  USB LS1208, two of them just for development purposes.
Thanks for your input in advance.
Mark.
(3,350 Views)
Hi Leatherneck,
it looks quite ok.
Two comments:
- I would separate the handling of different devices into separate loops.
- You can resize IndexArray to output more than one value.
(3,282 Views)
