LeCroy Connection
Hi.
I have downloaded the instrument drivers but when  from the block diagram, I go to Find Instrument Drivers and then I double click on lcwave (so i suppose that the drivers are installed properly) it shows me some VI example...the problem is that when I try to run these VIs in the VISA resource name the name of the LeCroy is not  shown. I have properly connected it with the ethernet connection.
Any tips?
Thank you
(3,524 Views)
Accepted by topic author inuyasha84
"Should be" isn't "Is" -Jay
(3,510 Views)
Mmm the problem was more "easy" ...simply the ethernet cable was broken. Smiley LOL now it works properly
Thank you for your help
(3,506 Views)
