LeCroy 6100a data acquisition through labview
I'm currently using LeCroy 6100a oscilloscope and i need to use labview to send command for it to trigger save table for parameter, then copy the saved file to labview. I'm connecting my oscilloscope and my PC through LXI.
Previously I'm using Read Waveform Measurement (Px) VI for the code as I have set the parameter in the oscilloscope and the value can straight be read from oscilloscope but the data acquire is too slow (8 data per second).
Any ideas for me to increase the acquisition of data?
Best Regards,
Oliver
(2,613 Views)
What does LeCroy say?  What does their manual suggest is the rate of data transmission?  Is this a LeCroy problem, a LabVIEW limitation, or a programming issue?  Hard to tell from your post (I'd guess #3, but have no data on which to base this guess).
(2,582 Views)
