Ldr sensor
When the light falls on an ldr sensr an led light should glow...can any one make a vi of this..plz....and also suggest how to connectt ldr to daq...an if any conversions needed in ldr connected daq assitant in software...plz reply make a vi of it
(5,881 Views)
What is an "ldr" sensor?
Once you explain that, you might be able to read the manual on it to see how to connect it, or someone on the forum may have a tip on how to connect it.
No one is going to make a VI for you.  Make your own and if you run into problems, post it here and people will help.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(5,878 Views)
LDR guess is Light Dependent Resistor aka photocell.
-AK2DM
(5,874 Views)
Sir i knew how to make vi logic for it but when i tried the ldr is showng me constant values even when i focused a light on it..so i have asked
(5,872 Views)
You did the "tell" part of "show and tell".  Now it is time for the "show" part.  Upload your VI.
Bill
CLD
(Mid-Level minion.)
(5,865 Views)
Basic wiring schema:
http://cactus.io/hookups/sensors/light/ldr/hookup-arduino-to-ldr-sensor
-AK2DM
(5,864 Views)
