Launch WebService without need LabView
Hi LabView Forum!
I have a doubt: I buid an WebService and then I deploy it, but I need to keep LabView oppened to access the service.
S, my question is: Can I build an WS and deploy it without LabView? Cause LabVIEW is a development tool, and my client dosn`t need this installed on his server.
P.S.:It`s a simple WS, you type ip/start on Firefox or IE and it starts, then you type ip/add, so it increments one at its value.
(3,166 Views)
Accepted by topic author LordVadher4
You could create an executable, so the customer only needs the LV runtime-engine. This is also accesible through the webinterface then.
Christian
(3,159 Views)
