Latching a Button to a Case Structure
Hi rvkamat,
BTW I found the solution.
That's not a solution, it's a quirky work-around…
Its apparently easier to automate scripts when you have an event structure.
From your description I guess it would be much easier to use a proper state machine. One state machine handling several "recipes". No event structures involved, atleast not for handling the recipe.
When this is your thesis you should also write a chapter on proper programming schemes…
Are you related to (or the same as) user rkamat?
Message 11 of 14
(677 Views)
Haha, Yes GerdW, I have 2 User Profiles.
I know this isn't "proper programming" but I am still learning. I have just been working with Labview this past month and I am sure I'll figure out these things on my own. I am sure you've had a boss who told you how he liked things and you "gladly" obliged.
Thanks for your help again!Smiley Happy
Message 12 of 14
(668 Views)
Hi GerdW,
Now that you mentioned it, I am using a State Machine. I have attached a pic, is this what you mean
Message 13 of 14
(652 Views)
Hi rkamat,
yes, those are state machines. You should prefer the Enum solution using a type-defined enum!
Message 14 of 14
(645 Views)
