Large File Access with Buffered and MMF
Hello, i need your help for optimization once again.
It's a common problem,
I must write large file results to a sequential file.
The initial data are float SGL type.
To achieve better performance the first idea here is to write into a Tab buffer.
When the buffer is full, it is flushed to the disk, thus enabling better write performance
than the direct I/O at each write.
The second idea is to write data with a size equal or multiple of a cluster size (defines as an external  param)
Thus, the buffer is flushed into a multiple chunck of data.
This introduces another buffer level
A third idea is to use different writing componet approach:
- Standard = one by one
- Labview Buffered = Labview component with the previous buffers
- Win32 Buffered = Win32 I/O component with the previous buffers
- Win32 MMF Buffered = Win32 using Memory-Mapped File with the previous buffers
Well Performance mainly depends on HD, but with my computer we can see the results:
(Win32 OS with HD, File size = 120 Mo, Nb Enreg = 2148000)
Standard:
- Read = 21163 ms
- Write = 120202 ms
Advantage/Drawback: Simple to Code but not the max perf
Labview Buffered:
- Read = 9444 ms
- Write = 48618 ms
Advantage/Drawback: Portable, Fast but RAM Buffer requirement
Win32 I/O :
- Read = 9401 ms
- Write = 48618 ms
Advantage/Drawback: Fast but Windows API only
MMF I/O:
- Read = 9623 ms
- Write = 181139 ms
Advantage/Drawback: Slow in Write and Windows Only
From these results, I notice that:
- MMF theorically should achieve the best performance,
in reality, it is not true. Due to page fault and swap ??
- Between Win32 Buffered and Labview Buffered Speed are nearly the same,
with a great advantage of portability for LV.
Thus, I focus on Labview buffered technique and search to optimize it.
Here, the Fill()/Flush() method are working but seem really complicated.
As the problem is recurant in the forum, I distribute the code in order it can serve other developpement.
I use (Standard and Labview Buffered in my programs, no intensive tests on Win 32 I/O, and MMF contains errors).
(See Class FileManager Access)
Can you help me to optimize Fill/Flush method !?
Best regards
Nicolas
(2,905 Views)
Good morning,
I think this links can help you to optimize your memory utilisation :
http://zone.ni.com/devzone/cda/tut/p/id/3747#toc0
http://digital.ni.com/public.nsf/allkb/071572F42CF4F3778625769A0034DFA7
http://zone.ni.com/devzone/cda/tut/p/id/9386
Nicolas M.
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter avec LabVIEW - Développer avec LabVIEW
(2,881 Views)
Thanks 4 the doc,
I must read more about the RefMemory InplaceElement (with the 0-1s icon)...
Here the images of FlushBuffer() and FillBuffer().
If I don't see how to optimize FlushBuffer() (any idea), I think there are more opportinuties with FillBuffer().
In FillBuffer(), I use the String Replace box to count the number of lines (\r\n), don't know if there is faster !?
And the use of reg expr PCRE box to split the String Buffer at a specified number of lines or less, looks pretty ugly code.
BR
Nicolas
PS: Altenbach one Rubby Ron Code more 😉 ??
(2,870 Views)
OK I understand New Data reference Node with inPlanceMemory Element.
In fact, I use a RefClass which use Queue to do this.
Is the InPlaceMemory More efficient than Queue ?
BR
Nicolas
(2,855 Views)
Up
(2,818 Views)
