Lap Timer
I was wondering if there is any way of modifiying this lap timer to be triggered by a DAQ. The DAQ has 5 infrared sensors as inputs which are placed around a track, the car passing it will trigger it. How could I get this working from the Lap timer circuit attached.
Any comments would be greatly appreciated
G
(2,837 Views)
Hi Shearer,
I would suggest instead of using sequence structure, you can use State Diagram architecture.
Can you tell us about 5 sensors?..How input from them should be used?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,833 Views)
