Lamp Control
Hi
Im using version 4.1 and im trying to control a lamp (hardware) by a
switch. The problem is that the voltage coming from the BNC 2090 was
only 2.9 V which isnt enough to light a 220 V lamp, it kept
triggering.
Then i used an amplifier (hardware), but I found out that when the
switch is OFF, 2.4 V are coming from the BNC board and that caused the
lamp to stay on whatever the state of the switch is.
I dont know how to fix this problem...
Note: im using digital configuration
(3,880 Views)
I'm not sure what you mean by using an amplifier, but the correct way to do this is have the digital output from your system controlling a mechanical or solid-state relay. This relay switches the 220v (which is coming from a seperate source) going to the lamp.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,880 Views)
I tried digital output, but the voltage wasnt enough to keep the lamp
fully on.. and when i tried to control 2 lamps, so little voltage
reached them...
then i tried analog output, it never worked...
i need some help as soon as possible..
thank you..
(3,880 Views)
You misunderstand. The idea is to use the digital output to control a relay. The relay turns on the power to the lamp. The power itself comes from an external source.
Mike...
LabVIEW Champion
(3,880 Views)
