Laggy GUI
my project is based displaying pictures and values from http web.
the more i add stuffs and indicators the more it gets laggy,
is there a way to make it less laggy?
it aint completed yet i have to add 3d parts and even more plots.
Message 1 of 9
(2,072 Views)
  1. Use the same HTTP session for all requests.
  2. Don't send empty requests.
Message 2 of 9
(2,060 Views)
  • All your "code islands" try to run in parallel, some communicating with the same device. Keep the connection open as already said.
  • Where is the top-level loop?
  • You only need to get the draw area once, so that belongs outside the top-level loop
  • Etc.
Message 3 of 9
(2,043 Views)
you mean something similar to this? same session for multiple purpose
also can you tell me what do you mean by empty sessions?
you mean the one with 192.168.4.1 empty with the structure case? can you suggest me a better replacement if you meant this.
Message 4 of 9
(2,001 Views)
i don't get what do you mean by top level loop? i use "run continuously" mode as i receive a stream of picture that i want to display so i it needs to be updated constantly.
i have provided the vi
Message 5 of 9
(1,997 Views)
I wish NI would move the billko_0-1687554171777.png button to a menu so inexperienced LabVIEW programmers can't find it.  The billko_1-1687554215168.png button is a diagnostic tool only and shouldn't be used in place of a proper loop.
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(1,966 Views)
Start reading here.
Quote: "Run continuously" is a misnomer. More accurate would be "restart the VI from scratch whenever it completes all of it's code".
Now read the rest of my post linked above (and maybe the entire thread).
Message 7 of 9
(1,951 Views)
It should not even show on the front panel. Maybe having it on the diagram only would be OK. (See also my comment here)
Message 8 of 9
(1,948 Views)
Ooh, judgement still hasn't been rendered on that idea so I added a kudos.
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(1,934 Views)
