Lag CANOpen controller and DAQ filters-CPU spikes
I am writing this one here because my basic LabVIEW skills are entirely exhausted,
This VI's main job:
-Aquire two analog signals, apply same filters(single USB-6009)
-Timely send a CANOpen message populated from the different controls(PCI-8531)
Problem:
-Non periodic CPU spikes on the 32bit dual core remote PC running the executable(no labview, only up to date .NET, XP USB Hotfix, DAQMx and NI-VISA ) we have built here (on a 32-bit dual core), when the CPU spikes, the gauges freeze, Toggle switch LED slaves dont light until the 3-8 second lag is over, happens every 10-40 seconds,
Kindly (I stress kindly, I read what you guys do to the other noobs) let me in on where I went wrong,
(2,508 Views)
Hi mtamim,
start with the most prominent problem: there are a lot of loops in your code that run at unlimited speed - grabbing all the CPU power they can get.
Use some decent waits in those loops!
When you have done that:
- using a statemachine approach might be applicable to the big sequence structure!
- using TimedWhileLoops is probably overkill when you just call the DAQAssistent in there...
(2,478 Views)
